Présentation
Post new topic   Reply to topic    VdM Racing Forum Index Les Autres Jeux Vos Autres Jeux rFactor 2 Le Paddock rFactor 2
PostPosted: Wed 11 Jan 2012 - 13:43    Post subject: Présentation Reply with quote
singe fou VictoireV singe fou
PostPosted: Wed 11 Jan 2012 - 13:43    Post subject: Publicité
PostPosted: Wed 11 Jan 2012 - 18:24    Post subject: Présentation Reply with quote
J'ai bon espoir de vous rejoindre bientôt mais l'enregistrement à un peu merdé et, donc, login impossible actuellement  Sad
j'ai appelé ISI à la rescousse ...
PostPosted: Wed 11 Jan 2012 - 18:38    Post subject: Présentation Reply with quote
Pour la première installation, un petit tuto dans le sujet des "mods"  ----->  ICI
PostPosted: Fri 17 Feb 2012 - 22:01    Post subject: Présentation Reply with quote
La Première mise à jour est téléchargeable.
Placez le fichier téléchargé dans votre dossier /rFactor2/Updates
Lancez le launcher
Allez dans update et installez
[VdM]Enrico62 (17/02/12), [VdM]MRC (18/02/12)
PostPosted: Sat 18 Feb 2012 - 16:23    Post subject: Présentation Reply with quote
Merci Laurent !
PostPosted: Thu 15 Mar 2012 - 20:48    Post subject: Présentation Reply with quote
The second update - Build 68
postcontent restore wrote:
Hi folks,
Thanks again for being testers.
Here is my post on the previous update, if you wanted to read that first.
Build 68 is available on the auto updater. Bit of a stress test for that updater.
A torrent, if you wish to download and install manually, is available here. You will also notice a torrent for the GT rfmod in the same place.
The GT mod has some known issues, none of which affect what we need testing, so we have released it as-is and will tidy up soon with an update.
Thanks,
Tim
[VdM]praxgtr (15/03/12)
PostPosted: Fri 1 Jun 2012 - 21:02    Post subject: Présentation Reply with quote
UPDATE 4 Changelog (MAY 18, 2012):
GRAPHICS:
Improved lighting math
Improved HDR rearviews
Fixed mirrors too dark when using HDR
Improved post-processing in multi-view mode
Fixed side-channel clearing in multi-view mode.
Fixed HDR in multi-view mode
Viewport fix for multi-view
Improved dynamic road
Changing shadow detail level now causes a shader re-compile
Changed base turbidity to 1.8 to brighten sky a bit.
Reduced minimum vertical FOV from 20 to 10 degrees.
improved graphical steering pivot for non-player vehicles
Now applying heat haze to graphics, note new PLR option "Heat FX Fade Speed" which can be used to completely disable.
Fixed broken HDR lum histogram
attempt to fix body parts disappearing in multiplayer
GAMEPLAY:
Added support for gear ratio sets.
Added ability to have gear-specific ratios.
Added DRS rules.
Added some GDB-configurable atmospheric conditions.
Changed flap buttons to act as toggle by default, but with a controller.ini option "Hold Flap Button" if the user prefers to hold it down.
SOUNDS:
Scrub sound improvements via the SFX file: can now have tire-specific samples, can be played individually rather than combined into one output, and more control over the frequency modulation.
Defaulting ScrubIndividually to true
AI:
fixed safety car incorrectly pitting for a tire change (and leaving the rest of the field in limbo)
fixes for AI pit lane behavior when no dedicated pitlane exists.
some minor tweaks to AI stalking behavior.
AI more likely to stay on throttle when along side a car they are trying to pass.
fixed a bug where cars would move towards rather than away from a car next to it going into a corner
fixed bug where sometime AI, at start of formation to standing start, immediately tries to park.
better handling of grip lose around fast corners
AIs will turn on and off rear flaps as required.
Tried to ease up on the throttle cuts caused by tires bouncing off the ground for a tick while otherwise being in control
PLUGINS:
Screen interface added to Internals Plugins in order to facilitate 3rd party overlays; currently untested and subject to change.
Now reporting to internals plugin whether blue flag being shown for each vehicle.
UI:
fixed the calculation of the "X display not available" X coordinates for MFD when under AI control.
added some gizmos and actions to facilitate multiplayer auto mod download and install from a dedicated server
added download mod status bar & cancel button
allowing problem mods to show up in lists (so that the problems can be displayed on the info screen)
added info buttons and code for rfm scrollbox to show new state of uninstalled mods with virtual components that are missing.
LED and HUD support for DRS status
changed scaling scrollbox gizmos (rfm, veh, track, hud, showroom & ui) so that they can accept textures other than 1024x1024 uncompressed textures.
Removed PLR file option "Wheels Visible In Cockpit" which was made obsolete by the VEH variable "FrontWheelsInCockpit" a long time ago.
BUG FIXES:
Fixed some unresponsive keys when using soft vsync.
Fixed problem with keyboard repeats in time acceleration.
Fixed warmup time increasing by 1 each time a server is set up.
Fixed problem where re-attaching a wheel in the pits would result in phantom collision.
Improved thread safety by using local file finder classes.
Fixed a error message that was incorrectly saying missing RCD files.
Fixed bug where requesting a pitstop while on the grid would sometimes cause a stop/go penalty.
Fixed 'Temporary Boost' button.
FUNCTIONAL ADDITIONS:
Added mod downloading to sim
Added settings for HTTP Server and rfmod sharing.
Added PLR variable "Car Vibration Mult2" in order to allow separation of orientational vs. positional effects, and added PLR variables "Seat Pitch", "Seat Yaw", and "Seat Roll" to allow an offset from which direction the cockpit camera points.
MOD MODE/PACKAGING
fixed not being able to switch UIs in mod mode.
removed "no ai" restriction from public dev build
added a scale value in HUD editor for flags & stat bar positions
got digital gages working in the HUD. Can now expand in any of four directions.
HUD editor stability fixes
HUD editor fixes. instead of numbers, will write out the function and font names for led, text, and digital gages
Téléchargement direct http:
Build 85: http://www.imagespaceinc.com/downloads/rF2_v1042-v1070_69-85.exe
MAJ de la build 69 à la 85: http://www.imagespaceinc.com/downloads/rF2_v1042-v1070_69-85.exe
Les mods:
-1960s World Class Racing: http://www.imagespaceinc.com/downloads/rfmod/ISI1045-v10-1960sWorldClassRac…
-Renault Megane Trophy: http://www.imagespaceinc.com/downloads/rfmod/ISI1032-v10-RenaultMeganeTroph…
+ update v1.1: http://www.imagespaceinc.com/downloads/rfmod/ISI1032-v10-v11-RenaultMeganeT…
-Formula Renault 3.5: http://www.imagespaceinc.com/downloads/rfmod/ISI1044-v10-FormulaRenault35s.…
+ update v1.1: http://www.imagespaceinc.com/downloads/rfmod/ISI1044-v10-v11-FormulaRenault…
+ update v1.2: http://www.imagespaceinc.com/downloads/rfmod/ISI1044-v11-v12-FormulaRenault…
-GT World Endurance: http://www.imagespaceinc.com/downloads/rfmod/ISI1050-v10-GTWorldEndurance.r…
+ update v1.1: http://www.imagespaceinc.com/downloads/rfmod/ISI1050-v10-v11-GTWorldEnduran…
-ISI Formula (2011) Masters: http://www.imagespaceinc.com/downloads/rfmod/ISI1052-v10-FormulaISIr.rfmod
PostPosted: Fri 1 Jun 2012 - 21:13    Post subject: Présentation Reply with quote
EN NORMANDIE??............. oheh
PostPosted: Fri 1 Jun 2012 - 21:25    Post subject: Présentation Reply with quote
Laughing conscience "professionnelle"!!!!
PostPosted: Sat 2 Jun 2012 - 00:35    Post subject: Présentation Reply with quote
eh ben...on entend tellement parler de rF2 que j'étais passé à côté de nouvelles caisses:
2 Nissan  dans la classe GT World, voir le lien dans mon précédent post.
Graphiquement, c'est juste horrible pour l'extérieur, le cockpit est mieux.
La conduite...ben j'y arrive pas  Laughing
PostPosted: Sat 2 Jun 2012 - 00:47    Post subject: Présentation Reply with quote
         Pour ma part .........j abandonne  definitivement RF 1 ET 2................. sauf si FFB mieux
PostPosted: Sat 2 Jun 2012 - 00:50    Post subject: Présentation Reply with quote
Bah rF1 pour moi c'est désinstallé depuis un moment.
Quant à rF2, je me ferais du soucis à leur place quand on voit ce qui arrive, Asseto Corse, GTR3, pCARS...
A priori la version définitive sort en juillet, je viens de testé avec toutes les updates...au secours!!
PostPosted: Sat 2 Jun 2012 - 01:07    Post subject: Présentation Reply with quote
               GTR  dabord    GTR2  for ever  depuis 2007.............je mise tout sur CARS           GTR3       depechez vous    ma patience a des limites       quoi que      a force
Post new topic   Reply to topic    VdM Racing Forum Index Les Autres Jeux Vos Autres Jeux rFactor 2 Le Paddock rFactor 2 All times are GMT + 1 Hour
