Avis et discussions sur Asseto Corsa
Goto page: <  1, 2, 3, 4, 5, 6, 7, 8, 9
PostPosted: Mon 31 Mar 2014 - 20:35    Post subject: Avis et discussions sur Asseto Corsa Reply with quote
lololol jolie skin
PostPosted: Mon 31 Mar 2014 - 20:35    Post subject: Publicité
PostPosted: Mon 28 Apr 2014 - 19:57    Post subject: Avis et discussions sur Asseto Corsa Reply with quote
  Je  n etais plus aller sur AC  depuis  un moment      c est  en francais maintenant  Okay
PostPosted: Fri 2 May 2014 - 18:04    Post subject: Avis et discussions sur Asseto Corsa Reply with quote
https://dl.dropboxusercontent.com/u/103005/AC/AC_online.pdf
http://www.assettocorsa.net/multiplayer-user-interface-walkthrough/
pour ce soir, il devrait y avoir le multi
ci dessus, le mode d'emploi pour se joindre a une partie
[VdM]Enrico62 (02/05/14)
PostPosted: Fri 2 May 2014 - 20:01    Post subject: Avis et discussions sur Asseto Corsa Reply with quote
derniere nouvelle
la sortie de laMAJ avec le multi est reportée   Evil or Very Mad
PostPosted: Fri 19 Dec 2014 - 10:17    Post subject: Avis et discussions sur Asseto Corsa Reply with quote
Assetto Corsa 1.0 is now available for download on Steam
Changelog:
1.0
- AI now brakes better in the pitlane
- Fixed problems with remote car colliders not properly turned off when disconnected
- Fixed DRS triggered from wheels
- More robust session status sync between server and clients
- Improved feedback to the kicked or disconnected user
- Improved car height calculation for a more uniform setup validation
- New Alfa Romeo Giuletta Q.V. 2014 Launch Edition
- Eliminated FFB vibration at 30kmh
- Updated tyre model for all cars
- Corrected bug in F40 old and street tyres
- Modifications on Lotus 98T and F.Abarth Aero map
- Modifications in engine brake on some cars
- Improved post processing effects
S1-Dynamic
S1-Sport
S1-Movie
S2-Photographic
S2-Retro70s
S3-Vignette
- New post processing effects
S1-Evolution
S1-Expanded
S1-Filtered
S1-Soft
S2-B&W
S2-B&W - HI
S3-Sepia
- New and improved photomode feature. Photomode activates from the replay User Interface
- New carbonfibre shader for cockpits of: bmw z4 gt3, bmw m3 gt2, Ferrari f40, Ferrari 599xx, Ferrari 458 gt2, ktm xbow, lotus evora gtc, lotus evora gtx, mclaren mp4-12, mclaren mp4-12 gt3, p4/5, tatuus
- Dirt layer optimization
- New skins for some cars, more to follow
- Small bug and fixes on trento bondone, magione, Spa Francorchamps
- Fmod project updated: no critical changes, just check volumes and envelopment for each event and mixer groups
- New sounds for Lotus Type 49, Ferrari F40 and Ferrari 312T
- Audio latency level can now be set in the launcher: available options are Normal, Low and Very Low
- Fixed FMod bug in multiplayer mode causing FPS drops
- Fixed wind volume for both stereo and surround configurations (default value: 0.7)
- Fixed bodywork sound audible for some cars when standing still
- Improved exterior sounds spatialization for surround speakers configurations
- Improved and balanced gearshift, backfire and limiter sounds
- improved positional sound for surfaces
- Overall volume balance
- Other minor audio fixes and improvements
- Added cutscenes for some of the career series.
- Improved algorithm for AI level while racing should give closer racing
- Inverted steering wheels and negative camber corrected for multiplayer clients
- Multiplayer basic admin tools:
Added simple admin commands using the chat window. It is important to set the "ADMIN_PASSWORD" in the server_cfg.ini file, an empty ADMIN_PASSOWORD will disable admin commands.
/help: prints the list of the available commands
/admin: become administrator for the server. ex, if the password is "kunos" the command is "/admin kunos"
/next_session: moves to next session
/restart_session: restart the session
/kick: kick a user using the rules (blacklist etc) of the server. To kick a player named "The Player": /kick The Player
- GT2 and GT3 cars, F.Abarth, Exos and Exos S1, M3 E30 GrA and DTM have now the modified tyre model
- LaFerrari has modified active aero and tyre model
- BMW M3 E30 street car has modified tyres (all compounds) as an example of street tyres new model.
- GT2 and GT3 cars have now the "old" FFB gain settings in their physics. Obviously the min FFB slider still works on them too. Please try and report back
- Zonda R, Huayra, 599XX have now tyres that are more load sensitive and more speed sensitive. Laptimes should be slower. Please give feedback on driving feel. Keep in mind you're going to be slower, give it some time.
- Minimum FF force implemented. Can provoke STRONG vibrations in the center zone, use as low as possible!
- All cars have new FF gain values to eliminate FF clipping. You might need to raise your FF gain values on your configuration or add a bit of minimum. Advice 0.12 for logitech wheels, much lower for other wheels. Experiment and report on beta forums
- Difficulty level slider on career
- Much more laps possible on single player quick and weekend races when fuel consuption is off
- Added diffuser stall on low speed for tatuus formula Abarth.
PostPosted: Fri 19 Dec 2014 - 10:31    Post subject: Avis et discussions sur Asseto Corsa Reply with quote
      Alors ca  veut dire  que c est la version  definitive   ?   DLL  gratuit  ou payant ?
PostPosted: Fri 19 Dec 2014 - 11:57    Post subject: Avis et discussions sur Asseto Corsa Reply with quote
Pour nous que l'avons dejà acheté gratuit Wink
PostPosted: Fri 19 Dec 2014 - 13:54    Post subject: Avis et discussions sur Asseto Corsa Reply with quote
       C est bien ce qu il me semblait,   cool   y a plus qua  Wink
Page 9 of 9
