Live Timing par Radiator Spring
Post new topic   Reply to topic    VdM Racing Forum Index Add ons
PostPosted: Sat 21 Dec 2013 - 10:11    Post subject: Live Timing par Radiator Spring Reply with quote
Live timing by Radiator Springs http://www.radiators-champ.com/RSRLiveTiming/index.php
Radiator Springs Racing Research and Development team proudly presents their first app for AC: RSR Live Timing.
The aim of our app is to bring a live hotlap competition to Assetto Corsa Early Steam Access.
At the moment our app is still a proof of concept, but it already includes all we need to make the competition fair and clean.
Just unpack the application in {Steam_AC_ home}
make sure you have the following new folder in the {Steam_AC_ home}\apps\python folder:
- RsrLiveTime
Make sure your personal details are filled in into the Profile in the AC gui
Your avatar will be automatically retrieved from your Steam account
Now start up Assetto Corsa and start driving
move your mouse on the rightmost of your screen. AC application bar will appear. click on RSRLiveTime app
The app will try to connect to the server and, after few seconds should show details about the track standing you are in.
and start driving.
You can see time difference from the other drivers clicking on the
 button.
RSR Live Time app will show you:
- position, lap time of the leader, and your gap from him
- position, lap time of the driver in front of you, and your gap from him
your position and lap time
- position, lap time of the driver behind you, and your gap from him
Only your valid laps will be tracked and sent to our server. If you go off track your time will not be logged.
There is an indicator to show if your lap is valid or not.
As soon as you will go off track, the indicator will turn red, and your time will be considered invalid, and will not be send to the live timing.
You can check full live results from our website.
Login using your steam account
and insert your steam username and password:
NOTE: in some cases steam recognize your account only with initial capital letter (i.e. if your account is yourSteamAccount, insert YourSteamAccount)
Your interface will be personalized with your own results, and will keep your favourite settings
You can choose the style of the website you want. We have three predefined styles: coloured, dark and simple. Choose the one suits you best.
The interface will also personalize the graphs with your results
On the website you can see driving aids used by the driver on his best time.
The application records details about the assists you used during your best time.
  • When the icon is red, means that that assist is enabled
  • When the icon is white, means that that assist is disabled
and your configuration. Hover on the info button
 to get more information.
If you want to see details about one driver, go into the Drivers menu, and search for him by inserting part of his name
We have 2 sections for stats:
By clicking on the Stats menu you can find statistics about every driver registered in the RSR Live Timing, and know more about how they have been using it so far.
By clicking on the Live Stats menu you can find statistics about drivers online, and know more about they are doing in this specific moment.
COMMON PROBLEMS AND RESOLUTIONS
  • In case of errors please check:
    • our application will create a log file {Steam_AC_ home}\apps\python\RsrLiveTime\{YYYYMMMDD}.log .
    • Please check also C:\Users\{your user}\Documents\Assetto Corsa\logs\py_log.txt
    • Please check also C:\Users\{your user}\Documents\Assetto Corsa\logs\log.txt.
  • You might find an hint of the issue there. In case you can't solve the problem yourself, please report it AC forum. This will help us improving our app and might help you solving the problem faster and start enjoying our app.
  • the application might not work in case you have a firewall that is blocking it. Please allow the {AC_TechPreview main folder}\apps\python\RsrLiveTime\wsLiveTime.exe to be executed and to have access to the network.
  • "FILE CHEAT ERROR" appears in case you have a not updated version of AC, or if you've modified anything that can influence your performances. Please make a clean copy of the latest AC.
  • in case you have issues with our app, try to manually delete the {Steam_AC_ home}\apps\python\RsrLiveTime\__pycache__ folder and try again.
  • In some cases it might be necessary to run AssettoCorsa.exe as administrator
  • In case of errors, our application will create a log file {Steam_AC_ home}\apps\python\RsrLiveTime\{YYYYMMMDD}.log . Please check also C:\Users\{your user}\Documents\Assetto Corsa\logs\py_log.txt and Please check also C:\Users\{your user}\Documents\Assetto Corsa\logs\log.txt. You might find an hint of the issue there. In case you can't solve the problem yourself, please report it on our forum uploading those 3 files. This will help us improving our app and might help you solving the problem faster and start enjoying our app.
PostPosted: Sat 21 Dec 2013 - 10:11    Post subject: Publicité
PostPosted: Sat 28 Dec 2013 - 14:18    Post subject: Live Timing par Radiator Spring Reply with quote
        Je me suis inscrit  sur le forum  d ASSETTO     il y a quelques jours .   Je vois bien pour pseudo  mais j ai pas acces au forum  Cool     je crois qu il parle  de mails  de confirmation envoyer   il doit y avoir un code.....J  ai pas  recu de mail  rien   l Adresse est bonne.......     (Your account is currently awaiting confirmation. Confirmation was sent t...................    voila  le message      une  solution
Last edited by [VdM]Devil Styl on Sat 28 Dec 2013 - 18:38; edited 2 times in total
PostPosted: Sat 28 Dec 2013 - 14:42    Post subject: Live Timing par Radiator Spring Reply with quote
Tu as fait clic sul Resend Confirmation Email ?
PostPosted: Sat 28 Dec 2013 - 18:36    Post subject: Live Timing par Radiator Spring Reply with quote
        LOl    j ai refais   un autre enregistrement    avec une autre adress mail   autre pseudo ,   ca marchait  toujours pas    et la   d un coup    sans mail     tutti va bene     j ai acces a  tout ...... Smile
PostPosted: Sun 29 Dec 2013 - 21:05    Post subject: Live Timing par Radiator Spring Reply with quote
      J ai installe  ce RSR LIVE      Wink             ca marche   c est cool   meme tres bien            sympa pour voir ou on  se situe     quoi        Cool          Laughing        ben  MONZA   en M3     c est cool  je suis dans le coup   Okay     dans les 75  premiers   pour  debuter    ..........
PostPosted: Mon 13 Jan 2014 - 10:46    Post subject: Live Timing par Radiator Spring Reply with quote
Nouvelle mise à jour pour ce plug-in:
Radiator Springs Racing has released a new version of their Assetto Corsa Live Timing plugin.
The plugin adds comprehensive live timing & leaderboard functionality to Assetto Corsa, the new version comes with the following changes:
v2.0.008 (10/01/2014):
NEW stats: most active drivers
NEW stats: wheel/keyboard
NEW stats: wheel model
NEW implemented PRO rank with multiple cars (more info on the PRO Rank in the guide)
NEW implement PRO rank with single car (more info on the PRO Rank in the guide)
NEW admin tools for handling automatic checks on drivers
NEW add pedals/shifter model in the info
NEW show if user is using paddle shifter or H-shifter in cars with H-shifter (Shifter: H-SHIFTER NOT USED)
NEW ABS default values considered as ABS OFF
NEW added max speed and car damage percentage
FIX deleted Drag times (413 records)
FIX problem with documents registry key not recognized
FIX workaround to handle drag laptimes correclty in v0.4.1
FIX improved communication between the app and the management system
Guide d'installation --> ICI
Leader board à consulter ---> ICI
Télécharger la nouvelle version ---> ICI  (en bas de la page)
[VdM]Enrico62 (13/01/14)
PostPosted: Mon 13 Jan 2014 - 11:21    Post subject: Live Timing par Radiator Spring Reply with quote
Merci mise a jour hier mais c est le 2.0.007 ! je regarde ca
PostPosted: Tue 14 Jan 2014 - 10:10    Post subject: Live Timing par Radiator Spring Reply with quote
Yes c est bien le 2.0.008 qu il faut maintenant Smile
PostPosted: Thu 23 Jan 2014 - 12:22    Post subject: Live Timing par Radiator Spring Reply with quote
RSR Live Timing for AC Version:2.0.009
[VdM]Enrico62 (23/01/14)
Post new topic   Reply to topic    VdM Racing Forum Index Add ons All times are GMT + 1 Hour
