Dream Pack 1
PostPosted: Wed 4 Mar 2015 - 18:01    Post subject: Dream Pack 1 Reply with quote
Et voilà le 1iere dream pack pour Assetto, en sale a 9,90 sur steam.
INFO
Dream Pack car list
Alfa Romeo 4C
Alfa Romeo GTA
Alfa Romeo 155 Ti V6
BMW M235i Racing
Corvette C7R GTE
McLaren F1 GTR
McLaren P1
Mercedes-Benz C9 LM
Mercedes-Benz 190E 2.5 EVO II
Nissan GT-R NISMO GT3
Nürburgring Nordschleife
Nürburgring Endurance
Turistenfahrten
loulou (12/03/15)
PostPosted: Wed 4 Mar 2015 - 18:01    Post subject: Publicité
PostPosted: Thu 5 Mar 2015 - 10:07    Post subject: Dream Pack 1 Reply with quote
Précommandé    Wink
PostPosted: Thu 5 Mar 2015 - 12:27    Post subject: Dream Pack 1 Reply with quote
dès hier soir !
PostPosted: Wed 11 Mar 2015 - 20:59    Post subject: Dream Pack 1 Reply with quote
Changelog Assetto Corsa 1.1
- Added ai-hints
- New penalty system
- Added Kick Quorum to the server
- Fixed sound pops and clicks for some cars engines
- Fixed traction control sound events
- Fixed Tatuus FA01 limiter sound
- Improved sound dynamics under load for some cars
- Launcher: more graceful handling of missing/problematic content
- Launcher default theme: personal best time grid filtering by car/track added
- Fixed blank resolution box
- Fixed missing sound events
- Fixed crashes volume
- Reworked envelopment for interior and exterior sounds
- Higher exterior volume for surround speaker configurations
- Fixed tyre fake shadows in slowmo replay
- Improved AI
- Added custom head movements per car (driver3d.ini)
- Driver helmet/head now cast shadows in onboard camera
- Added custom weather selection
- Improved Pedals App
- Rendering performance optimizations
- Particle rendering optimiziations
- Render Stats form now features units
- Added “final” damage for high speed impacts
- Added quality settings to replay that allow up to 4x longer replays
- Fixed driver shift preload animation at race start
- Fixed camera car not using FOV value
- Fixed AI choosing wrong (slow) tyres
- Updated FMod to 1.05.13
- Updated Fmod SDK project (minor envelopment improvements)
- Tweaked exterior reverb parameters
- Tweaked envelopment values for some sound events
- Improved positional surface sounds
- Fixed wind and tyre rolling noise
- Fixed doppler effect for rev limiter and horn
- Fixed FOV in mirrors, now editable in system/cfg/assetto_corsa.ini
- AI race starts greatly improved
- Fixed wrong shadow resolution when moving through F6 camera car cameras
- Fixed graphics not following dynamic track grip levels in Multiplayer
- Fixed “fast” height evaluation for validating setup ignoring tyre pressure
- FPS caps is now compatible with the new 1ms resolution timer
- Suicidal server admins are now a protected species and not allowed to kick themselves anymore – Adjusted fuel consumption for most of the cars
- UI now understand fuel range relative to car and track and adjust maximum race lap count automatically for quick races and race weekends against the AI
- Added 4WD simulation in drivetrain.ini
- Added live axle suspension geometry
- [DATA] section in aero.ini is now obsolete and must be eliminated. HEADER=2 is mandatory if damage is used.
- AC now support multiple configurations on circuits
- A to B gameplay options for hillclimb tracks and specific circuits that support.
- Tyre pressures can now be shown in digital_instruments.ini
- Limited static weather situations can now be selected from the UI. Weather is also moddable.
- Time Attack now has a global multiplier that controls the amount of time available for the first checkpoint.
- Customizable TrackIR rotation range.
- Chat window now supports full Unicode charset
PostPosted: Thu 12 Mar 2015 - 09:05    Post subject: Dream Pack 1 Reply with quote
 Bon, je me suis un peu occupé de ASSETTO CORSA.
J'ai mis l'Addon Dream pack qui doit en principe être pas mal!
Mais voilà, ça m'a foutu la M.............
Tous les mods que j'avais rajoutés bloquent le jeu ainsi que les APPS.
Du coup, j'ai refait une nouvelle install et je repart à 0.
Pour la qualité graphique, je ne peu pas me prononcer, car avec la carte graphique que j'ai, c'est moyen.
PostPosted: Thu 12 Mar 2015 - 09:22    Post subject: Dream Pack 1 Reply with quote
Normal Rod, il faut attendre que les moddeurs ils mettent les patch différents. Je te conseille de regarder souvent sur Racedepartement ou sur le forum officiel de Assetto pour trouver les ajournements.
Dejà 3-4 mod maj....sont fast les gars.....
PostPosted: Fri 13 Mar 2015 - 09:41    Post subject: Dream Pack 1 Reply with quote
http://www.racedepartment.com/downloads/patches-v1-1-for-modded-cars-new-guids-original-banks-of-the-mods.5525/
Ici une "general fix" pour beaucoup de mods, et aussi des autres fichier.
Pour info: combien de nous ils ont pris le dream pack? Pour pouvoir organiser quelque soirée et prendre confidence la plus possible avec AC, comme par exemple ce soir, Vendredi13.....(lol....) nous pouvons nous trouver sur le Green Hell avec différentes autos....
PostPosted: Fri 13 Mar 2015 - 10:47    Post subject: Dream Pack 1 Reply with quote
Bien, maj de AC sur Steam avec aussi les fix mods:
v1.1.1
- Launcher: new option in Options > General to ignore Windows' display scaling
- Launcher: launcher will now reset to default theme on version change
- Launcher: potential fix for rare crash on exit
- Launcher default theme: further additions to the handling of missing/problematic mod content
- Added Visual Studio DLLs
- Now correctly set replay speed for replay files recorded with older versions of AC
- improved exterior m235i backfire envelopment
- Corrected C9 numbers on skin
- Corrected Alfa GTA tyres naming
- Custom post processes are now correctly located by the launcher in Documents/Assetto Corsa/cfg/ppfilters
    PostPosted: Fri 13 Mar 2015 - 10:50    Post subject: Dream Pack 1 Reply with quote
    Présent !   Okay
    [VdM]Enrico62 (13/03/15)
    PostPosted: Fri 13 Mar 2015 - 10:59    Post subject: Dream Pack 1 Reply with quote
        J achete pas.......seulement 2 voitures me plaisent    et la Corvette elle est deja la non !   le reste bof...  Achete de dream 1 , achete le dream 2   pffffff
             C est pas une question de monnaie.....AC  au début   nickel  ,  tout marchait  bien  et bon ressenti  ,   après plus de live  , plus  d apps ,  plus mes sets ,  j ai  repris mon g 27   ,  il faut tout rerégle   repffff   j ai la flemme  en faite .   Le online les pits , et le reste    je ne suis pas trop AC   finalement.
            Je ne vais pas critique  , mais  75%  des voitures  je m en fous  .  Une licence  avec 3 bm , une autre avec 2 mc Laren etc  comme gt5 ou 6   des caisses de route  , tout mélanger  ca me saoule..... S il faisait  les voitures  d un championnat style Blancpain  ou autre  comme une époque sur gtr2    ok....
             Je passerai plus sérieusement  a AC  plus tard ,   quand ca  sera mieux en place  Rolling Eyes
    PostPosted: Fri 13 Mar 2015 - 11:51    Post subject: Dream Pack 1 Reply with quote
    https://support.steampowered.com/kb_article.php?ref=2037-QEUH-3335&l=french
    Si tu as des prob avec AC (ou pour toutes les jeux sur Steam).
    Pour le Dream.....seul le Nords en laserscan il vaut l'achat....
    Pour le reste il est subjectif, il nous manquerait, il y a déjà 4 GT3+ 1 dans le DP, (pour parler de Blancpain), 2 GT2 et ils viendront beaucoup d'autos aussi historiennes, je suis ensuite sûr que tu le recommenceras à utiliser en avenir.
    Pour le volant, il y a beaucoup d'info sur le forum officiel.
    PostPosted: Fri 13 Mar 2015 - 12:53    Post subject: Dream Pack 1 Reply with quote
         Tu as raison  Enri     je pense que AC   est l  avenir  ,   dans le futur ( pas trop  hein....)  il y aura  beaucoup  de voitures  et on aura un bon choix Smile
            et  je roulerai  ...  sinon  plus que GTL   et je ne roulerais plus avec Vous..... Pour l instant  je reconfigure( plr  réglages)  comme il faut  du G27  pour GTL .
         Et je compte peut etre passer au T500     et fourguer   ce Fanatec  avec lequel   je n ai jamais eut un bon ressenti  ,   je redecouvre le plaisir de rouler avec le G27    c est peu dire...........
    PostPosted: Fri 13 Mar 2015 - 13:01    Post subject: Dream Pack 1 Reply with quote
        La GTA       c est vrai quelle a de la gueule
