Assetto Corsa V1.3 + DLC Pack2
PostPosted: Thu 8 Oct 2015 - 19:51    Post subject: Assetto Corsa V1.3 + DLC Pack2 Reply with quote
Here is the full changelog straight from the devs:
  • "64bit build
  • Car physics is now calculated in separate threads
  • Fixed KERS disabled in pitlane
  • Added soft locks (use [SOFT_LOCK] ENABLED=1 in system/cfg/assetto_corsa.ini)
  • Added support for DRS zones
  • acServer is now stressing much less Go' GC and should offer more stable performances
  • Added FORCE_TGT to force low res timer in assetto_corsa.ini
  • acServer is now using Go 1.5, faster GC
  • Added server welcome message
  • Fixed gear ratio appearing with a double "/" in setup screen
  • Fixed acServer unable to read ini values with a "=" character (ex AUTH)
  • Fixed driver name displayer not obeying to saved settings in MP
  • Fixed acServer not creating "results" folder automatically
  • New algorithms to calculate skid volumes and pitch, now working globally in the entire simulation
  • Added grain and blister readings in the setup info screen
  • Added downshift protection to gearboxes
  • Lap count is now reported using 16bit unsigned integer to server plugins
  • Now using triple buffer when vsync is on to reduce latency
  • Exposure settings are now persistent
  • Fixed audio clicks on surface events
  • Tyre flat spots are now taking into account tyre softness
  • Windscreens now receive shadows
  • ksEditor: now it uses the same ingame engine.
  • ksEditor: added project menagement
  • ksEditor: added user personalizations
  • ksEditor: added floating windows and layout system
  • ksEditor: added Weather and PPfilter loader
  • ksEditor: added recent files/project management
  • ksEditor: added node filter in scene panel
  • ksEditor: added Material by Texture in Materials panel
  • ksEditor: added scene icons and side function buttons
  • ksEditor: added texture detail on Material panel
  • ksEditor: added Texture Review windows in Utilities
  • ksEditor: fixed reload texture function
  • ksEditor: now the default CultureInfo is en-US (number format, ect)
  • ksEditor: added FOV, Near Plane Slider, Mouse sensitivity, camera angle and position under Viewport
  • ksEditor: added Dashboard tab
  • acServerManager: removed some upper limits on parameters
  • acServerManager: preset name/description is more clear
  • acServerManager: added welcome message
  • acServerManager: added qualify limit
  • acServerManager: added fixed setup management
  • acServerManager: fixed upload on ftp. Now cfg folder is not deleted.
  • Fixed driver textures on serveral cars
  • Fixed circuit outline on track selection UI
  • Camera Dev App now save F1 cameras' exposure and pitch, F6 cameras' exposure, fov and position and angle
  • Removed background from Performance Delta App
  • Redesigned and faster code for logging
  • Updated Tyres V5 for GT2 and GT3 cars, should give less understeer.
  • Zonda R and Ferrari 599XX and Formula Abarth now have V5 tyres.
  • Less lift off oversteer for Evora S on street tyres V5
  • GT3 and GT2 cars updated aero stalling for front splitter and diffuser
  • GT3 slight performance balancing
  • Mclaren MP4 GT3 tyre corrections
  • Fixed TC digital item showing 0 based index when multiple TC level are available
  • Now showing Cold and Hot pressure readings in setup status
  • Added "NA" for IMO temps reading when no set has been swapped out
  • Added support for track dynamic objects
  • It is now possible to join a server using admin passoword and be automatically granted admin rights
  • Joining a server with admin password will override the session "closed" status
  • Added "ban_id" admin command to ban a user and send straight to blacklist
  • Remote cars in multiplayer now generate skidmarks
  • Fixed EDL wrong calculation order"
Pour le DLC Pack2 en promo à €7,99
- circuit de Catalunya (Barcellona): GP e Moto.
- AUDI R8 Ultra 2014
- BMW 4M Coupé
- BMW 4M Coupé Akrapovic Edition
- FORD GT40 MK1
- Lamborghini Countach 5000 Quattro Valvole
- Lamborghini Huracan GT3
- Scuderia Glickenhaus SCG003
- RUF RT12R   RWD et 4WD
PostPosted: Thu 8 Oct 2015 - 19:51    Post subject: Publicité
