2015 AUDI R8 LMS
Post new topic   Reply to topic    VdM Racing Forum Index Les Mods
PostPosted: Fri 5 Feb 2016 - 22:22    Post subject: 2015 AUDI R8 LMS Reply with quote
1st mod pour p.Cars by Machinedojomt http://machinedojomt.weebly.com/downloads.html
Lisez bien le readme pour l'installation.
PostPosted: Fri 5 Feb 2016 - 22:22    Post subject: Publicité
PostPosted: Fri 5 Feb 2016 - 23:05    Post subject: 2015 AUDI R8 LMS Reply with quote
Je vois " DOWNLOAD : " mais rien à cliquer...
Je ne vois aucun lien sur cette page....http://machinedojomt.weebly.com/downloads.html en dessous de l image de la R8.
Comment il faut faire Enrico ?
PostPosted: Fri 5 Feb 2016 - 23:17    Post subject: 2015 AUDI R8 LMS Reply with quote
http://adf.ly/1WX6i3
PostPosted: Fri 5 Feb 2016 - 23:36    Post subject: 2015 AUDI R8 LMS Reply with quote
Merci Enrico ! Okay
PostPosted: Sat 6 Feb 2016 - 20:47    Post subject: 2015 AUDI R8 LMS Reply with quote
Vous êtes arrivés à installer cette Audi avec le JSME car je n'y arrive pas ?
PostPosted: Sat 6 Feb 2016 - 21:24    Post subject: 2015 AUDI R8 LMS Reply with quote
Oui Rox, regarde bien le readme pour l'installation et aussi pour le desinstallation....il fau travailler un peu.
MAJ 1.03 http://www.mediafire.com/download/j1dg17iia4k3n4m/Audi+R8+LMS+2015+v1.03.rar  il est necessaire desinstaller l'ancien version.
2 dossier: pour 32 bit et pour 64 selon votre PC.
Les texture du mod sont superbes!!
2015 Audi R8 LMS v1.03 by Machine Dojo Modding Team
Installation:
1. Since this is an add-on car, you need to install the Unpacked Boot Files first. Latest version is available here: http://autoprophets.weebly.com/home/unpacked-boot-files-for-project-cars
2. Copy the folder "Audi R8 LMS 2015" into the folder "MODS" in the game's dictionary.
3. Run "JSGME.exe" in the game's dictionary, press ">" to activate "Audi R8 LMS 2015". Then the program will give you a warning beacause this mod covers some files of other mods. Normally this causes no problems, so just go ahead and press "Yes".
4. Run "Audi R8 LMS Install.bat" in the game's main folder to get the car registered.
5. Enjoy!
Uninstall:
1. Run "Audi R8 LMS Uninstall.bat" in the game's main folder to clear the registry.
2. Run "JSGME.exe" in the game's main folder, select "Audi R8 LMS 2015" on the right and press "<" to disable it.
If you're installing an updated version of this mod with the old version already installed:
1. Disable the old version in "JSGME.exe"
2. Delete the old mod files in the folder "MODS".
3. Copy the new files there and activate the new version. Registering steps are not necessary when updating the mod.
If a new patch of the game is available and you need to update the "Unpacked Boot Files":
1. Disable all mods including the "Unpacked Boot Files" via "JSGME.exe" before updating the game in Steam.
2. Download and install the new "Unpacked Boot Files" for your game version.
3. Activate and register this mod again.
PostPosted: Sat 6 Feb 2016 - 22:01    Post subject: 2015 AUDI R8 LMS Reply with quote
ATTENTION
risque de ban des serveurs steam si vous allez sur des serveurs "VAC" (Valve Anti Cheat)
éviter les serveurs avec le sigle VAC si vous utilisez ce mod, ou desactivé par le jsgme.
PostPosted: Tue 9 Feb 2016 - 22:08    Post subject: 2015 AUDI R8 LMS Reply with quote
Tutorial installation.
https://www.youtube.com/watch?v=kp8PcC1PBDM
PostPosted: Today at 23:59    Post subject: 2015 AUDI R8 LMS
Post new topic   Reply to topic    VdM Racing Forum Index Les Mods All times are GMT + 1 Hour
