Assetto Corsa 1.5
PostPosted: Fri 1 Apr 2016 - 08:32    Post subject: Assetto Corsa 1.5 Reply with quote
- New Abarth 595esseesse and S1, S2 upgrades
- New Ford Mustang GT 2015
- New Corvette C7 Stingray
- New Black Cat County track
- Nurburgring gp circuit updated
- Nurburgring gp circuit now with 4 layouts
- Silverstone circuit updated
- Monza circuit updated
- Spa circuit updated
- Nurburgring Nordschleife circuit updated
- Nurburgring Nordschleife endurance cup layout added
- Mugello circuit updated
- Magione circuit updated
- Imola circuit updated
- Drift circuit updated
- Vallelunga circuit updated
- Vallelunga classic layout added
- Vallelunga circuit (all layouts) now has 24 car slots
- Activated time progression in Multiplayer
- All cars updated to Tyre Model 7
- Pitstop are now available in single player races
- Damage is now visible in Multiplayer mode for remote cars
- Launcher: steam overlay support disabled due to stability issues
- Launcher: re-instated multi-process mode for CEF due to stability issues
- Launcher: changes to memory usage policy, more aggressive memory releasing thresholds
- Fixed Lamborghini Miura gearbox damage
- Updated drivetrain upshift and downshift timings for all cars
- F6 inside cameras use internal sounds
- Free camera now honours distance multiplier for sound attenuation
- Of all Drivable cameras only Cockpit uses internal sounds
- Transmission sound can have its own volume (by default it shares engine volume, otherwise it uses the TRANSMISSION value set in audio.ini)
- Gearshift sound shares engine volume
- Backfire sound shares engine volume
- Fixed car sound when bottoming out
- Realtime app shows lapped guys (blue) and lapping guys (green)
- Fixed FuelLapEvaluation function
- Fixed fuel consumption on turbo engines
- Fixed inconsistency on UI tech specs
- Modding : added FormCamera functionality to associate internal/external soundset
- Modding : added console commands "observeLights" and "observeFlames" (work as observeDigital); EDIT_MODE is deprecated
- Modding : added Digital Instrument KERS_CHARGE (percentage)
- Modding : added Digital Instrument TOTAL_LAPS (if session is not race then "---")
- Modding : added Digital Instrument CURRENT_LAP
- Modding : added Digital Instrument EST_LAPS (if est is less than 0 then "--.-")
- Modding : added Digital Instrument AMBIENT_TEMP
- Modding : added Digital Instrument FUEL_CONS (UNITS: MPG_UK, MPG_US, L100 or "Kms per Liter" if missing)
- Modding : added Digital Instrument PLACE_HOLDER to avoid fixed digits on texture (use TEXT)
- Modding : added ON_BOARD_LOOKBACK_OFFSET in car.ini
- All tyres now use V7 with brand new heating values (beta: except Exos F1 tyres yet)
- All tyres now use V7 with brand new falloff level and speed (beta: except Exos F1 tyres yet)
- Changed all tyres flex and pressure relation.
- Changed all tyres footprint and pressure relation
- Modified global aero efficiency with yaw angle. Works on all cars
- Added new aero.ini version=3 with new YAW_CL_GAIN values that can stall wings depending on yaw angle
- Yaw angle stalling wings and diffusers for GT2/GT3 cars and Mercedes C9 and Lotus 98T
- All GT2/GT3 cars now have minimum height 55mm
- 200,400,500,1000,2000 meters drag circuits now available
- Modding : ksPreviewBuilder added to sdk/dev folder
- Python Interface:
- initFont(fontfamily, italic, bold)
- setCustomFont(fontfamily, italic, bold)
- getCameraMode()
- setCameraMode(acsys.CM)
- getCameraCarCount(carId)
- setCameraCar(F6 camera index, carId)
- focusCar(carId)
- getFocusedCar()
- getServerName()
- getServerIP()
- getServerHttpPort()
- getServerSlotsCount()
- isCarInPitline(carId)
- isCarInPit(carId)
- isConnected(carId)
- getCarBallast(carId)
- getCarState(carId)
- eKersCharge
- eKersInput
- totally revamped backfire system (will not break mods)
- added new F1 "dash camera" and "Chase camera #2"
- CameraManager : fixed issue globalCameraIndex
- Fixed Camera selection on Replay Interface
- Fixed CameraApp to reflect Dash and Chase changes
- Fixed Camera system messages
- Fixed Random camera wrong cameras + message
- added CameraOnBoard offset to avoid car parts on view
- added new driver model with lod
- added Fuel Lut to solve issues with several cars gauges
- SharedMemory : added new members
- SPageFilePhysics
float turboBoost = 0;
float ballast = 0;
float airDensity = 0;
- SPageFileGraphic
int isInPitLine = 0;
float surfaceGrip = 0;
- SPageFileStatic
float maxTurboBoost = 0;
float airTemp = 0;
float roadTemp = 0;
bool penaltiesEnabled = false;
float aidFuelRate = 0;
float aidTireRate = 0;
float aidMechanicalDamage = 0;
bool aidAllowTyreBlankets = false;
float aidStability = 0;
bool aidAutoClutch = false;
bool aidAutoBlip = false;
- fixed several cars still featuring dashboard "floating" digits
- fixed car scraping volume
- added first implementation of Force Feedback Post Processing (docs in cfg/ff_post_process.ini)
- improved camber calculations
- improved tyre heating on low friction surfaces (grass,sand etc)
- added new "Tyres" app
- Server lap counters and lap times are now 16 bit unsigned ints allowing super long sessions/races
- Ford GT40 fuel tank position fixed
- revamp of all digital displays and script
- revamp of analogue gauges
- Lamborghini Huracan GT3 3D model tweaks
- Lotus Exige S model tweaks
- Various LOD fixes across the entire vehicle content
- BMW M3 GT2 3D model tweaks
- Roof on the LaFerrari is now customizeable
- Emissive values tweaked on some cars to improve visibility with PP off
- Various skin issues fixed
- PP preset improvements
- Improved AI behavior in traffic
roxan12 (01/04/16)
PostPosted: Fri 1 Apr 2016 - 08:32    Post subject: Publicité
PostPosted: Fri 1 Apr 2016 - 13:18    Post subject: Assetto Corsa 1.5 Reply with quote
Testé et bonne évolution du jeu.
Par contre je trouve que le son en vue capot n'est pas le bon (trop de réverbération, comme si on était en cabriolet).
Je préfère le son de l'auto en mode cockpit.
J'ai vérifié pour la Porsche du prochain championnat et pas de perturbations en conduite. Donc OK!
oups  Rectification:
Il y a une nouvelle application installée maintenant dans le jeu.
Un réglage des différents sons depuis la piste.
Donc j'ai rien dit.
PostPosted: Fri 27 May 2016 - 21:26    Post subject: Assetto Corsa 1.5 Reply with quote
Hé Rod, quand est ce que tu nous concoctes une 'tite soirée AC?
Type: 2 manches de 20-25mn
Ce serait cool Smile
PostPosted: Thu 2 Jun 2016 - 08:16    Post subject: Assetto Corsa 1.5 Reply with quote
Assez occupé en ce moment. Et pas trop envie d'organiser! Lassé du manque de participants à chaque fois que je lance quelque chose sur assetto!
PostPosted: Fri 3 Jun 2016 - 17:38    Post subject: Assetto Corsa 1.5 Reply with quote
Moi le l'ai,  je ne m'en sers pas...trop compliqué,  trop de truc à rajouter,  payer  Mad   le jour ou il y aura un kit
tout en un à installer on verra, mais je n'y crois pas trop, payer, payer, payer...
c' est vrai qu on a deja du mal a avoir 10/12 inscrit pour un champ pour le finir a 7/8...
PostPosted: Fri 3 Jun 2016 - 19:58    Post subject: Assetto Corsa 1.5 Reply with quote
C'est vrai que ce serait sympa une 'tite promo sur les DLC
PostPosted: Fri 3 Jun 2016 - 20:37    Post subject: Assetto Corsa 1.5 Reply with quote
Pas necessaire acheter les dlc, i l ya mod et piste extra free, il est suffisant utiliser ou auto d'origine ou mod.
Et pour une petit "Summerchamp" je peux le organiser....mai j'ai besoin de un server......
Leo80 (03/06/16)
PostPosted: Sat 4 Jun 2016 - 08:33    Post subject: Assetto Corsa 1.5 Reply with quote
Si on est suffisamment nombreux,  je veux bien tester,  mais pour le moment je n'achèterai rien de plus...
Donc de l origine s il y a des choses intéressantes...?!
PostPosted: Sun 5 Jun 2016 - 21:52    Post subject: Assetto Corsa 1.5 Reply with quote
Si voulez faire un test Lundi soir (06/06) avec un mod et une piste d'origine pour une future mini-summerchamp je mette mon server:
VDM Racing
Pass: enri
Piste Vallelunga Club d'origine 10 tours en Gr.2
Auto: Mod Abarth 1000tc    http://www.racedepartment.com/downloads/abarth-1000tc.8424/
Piste Magione d'origine  10 tours en Gr.5
15 min de qualifs a chaque course
A partir du 21h avec essais, qualif 1 à 21h30
Leo80 (06/06/16)
PostPosted: Mon 6 Jun 2016 - 00:15    Post subject: Assetto Corsa 1.5 Reply with quote
Moi, suis partant  Okay
PostPosted: Mon 6 Jun 2016 - 05:42    Post subject: Assetto Corsa 1.5 Reply with quote
Allez... Razz
PostPosted: Mon 6 Jun 2016 - 19:05    Post subject: Assetto Corsa 1.5 Reply with quote
salut !
ok pour moi
PostPosted: Mon 6 Jun 2016 - 20:20    Post subject: Assetto Corsa 1.5 Reply with quote
Salut.
Je ne voie pas de serveur?
PostPosted: Mon 6 Jun 2016 - 22:51    Post subject: Assetto Corsa 1.5 Reply with quote
Bien sympa cette soirée.
Pas facile à dompter la petite italienne...
Merci Enrico Okay
PostPosted: Mon 6 Jun 2016 - 22:52    Post subject: Assetto Corsa 1.5 Reply with quote
 les gars pour la soirée test.
Abarth 1000tc sympa sois la gr2 que la gr5, et bravo les pilotes avec des bon crono en piste.
A refaire
Rodnoil56 (06/06/16), Leo80 (06/06/16), [VdM]Devil Styl (07/06/16), Ray Moulad (07/06/16)
