[9 12 2010] TSUKUBA CHAMPIONNAT VdM MEGANE TROPHY
Goto page: 1, 2, 3, 4, 5  >
PostPosted: Fri 3 Dec 2010 - 00:17    Post subject: [9 12 2010] TSUKUBA CHAMPIONNAT VdM MEGANE TROPHY Reply with quote
  • MOD:disponible sur 9Giga/GTR²/Mods/Renault/GTR2-eurocupmeganetrophy.zip
  • CIRCUIT:disponible sur 9Giga/GTR²/Circuits/TSUKUBA.zip
  • QUALIFICATIONS: 21H30 - 22H00
  • COURSE 1: 20 TOURS
  • COURSE 2: 20 TOURS (GRILLE DE DEPART INVERSE DES QUALIFS
INSCRIPTIONS  ET RESERVATIONS DES VOITURES------------------->  VOIR ICI
PostPosted: Fri 3 Dec 2010 - 00:17    Post subject: Publicité
PostPosted: Fri 3 Dec 2010 - 23:08    Post subject: [9 12 2010] TSUKUBA CHAMPIONNAT VdM MEGANE TROPHY Reply with quote
Une piste courte, pourtant amusante Smile
Voici un petit gâteau pour ouvrir l'apetit...
PostPosted: Fri 3 Dec 2010 - 23:31    Post subject: [9 12 2010] TSUKUBA CHAMPIONNAT VdM MEGANE TROPHY Reply with quote
 super!! merci Prax
PostPosted: Fri 3 Dec 2010 - 23:40    Post subject: [9 12 2010] TSUKUBA CHAMPIONNAT VdM MEGANE TROPHY Reply with quote
Belle remonter c'est moi le couteaux entre les dents Gaz Banzaiiiii Mr. Green  merci Prax joli bruit les mégane j'adoreeeeeeeeeeeeeee Okay
PostPosted: Sat 4 Dec 2010 - 00:15    Post subject: [9 12 2010] TSUKUBA CHAMPIONNAT VdM MEGANE TROPHY Reply with quote
SA SERA SANS MOI IMPOSSIBLE DE ROULER ELLE M'ECHAPPE Crying or Very sad Crying or Very sad  MALGRE LE SETUP DE PRAX, J'AI L'IMPRESSION DE ROULER SUR DE LA GLACE MEME AVEC AILERON A 5
PostPosted: Sat 4 Dec 2010 - 02:06    Post subject: [9 12 2010] TSUKUBA CHAMPIONNAT VdM MEGANE TROPHY Reply with quote
un peu de courage Gaz...
Tu en as vu d'autres.. tu vas y arriver...
Modifie tes rapports de boite, mets des rapports plus long quitte a pas passer la sixième...
Enfin...pas d'abandon...pas VDM ca !!
PostPosted: Sat 4 Dec 2010 - 10:32    Post subject: [9 12 2010] TSUKUBA CHAMPIONNAT VdM MEGANE TROPHY Reply with quote
tu roule au pad gaz ?
PostPosted: Sat 4 Dec 2010 - 10:57    Post subject: [9 12 2010] TSUKUBA CHAMPIONNAT VdM MEGANE TROPHY Reply with quote
Oui c'est PadMan!!!
PostPosted: Sat 4 Dec 2010 - 11:48    Post subject: [9 12 2010] TSUKUBA CHAMPIONNAT VdM MEGANE TROPHY Reply with quote
Me*de alors ! pour un padman tu te débrouille clap
bien que les meganes sont rivées au sol ,c'est clair que se ne doit pas être évident sur tsukuba  ,
je ne me rappel plus de se qui est paramétrable dans le setup...faudrait voir comment diminuer au max le survirage .
Se serai vraiment dommage que tu ne participe pas ,surtout maintenant que tu nous a mis l'eau a la bouche ,et rameuté la moitié des cda Sad
    >>>>il faut lire : c'est con !
Mr. Green
PostPosted: Sat 4 Dec 2010 - 11:54    Post subject: [9 12 2010] TSUKUBA CHAMPIONNAT VdM MEGANE TROPHY Reply with quote
Gaz nous a habitué à plus difficile avec son Pad !!!
Certes sur Tsukuba on se bat avec le volant et on dose à mort sur l'accélérateur sinon sucette, mais la Magane accroche la moquette quand même!
On a pas pondu des 0 52 ou 0 53 en 2 tours non plus....parfois GTR2 demande du travail, allez Gaztéropad!!!! courage!!!
PostPosted: Sat 4 Dec 2010 - 14:58    Post subject: [9 12 2010] TSUKUBA CHAMPIONNAT VdM MEGANE TROPHY Reply with quote
GAZ BAD BOY ET' ATTENDU JEUDI' EN PISTE AU TSUKUBA, SINON  tete   MAIS PLUS EN BAS' QUE LA TÊTE...
PostPosted: Sat 4 Dec 2010 - 19:15    Post subject: [9 12 2010] TSUKUBA CHAMPIONNAT VdM MEGANE TROPHY Reply with quote
 j'ai enfin trouver la solution a mon problème de drift, j'avais les 2 version "Tsukuba et Tsukuba Circut Drift Version" depuis que j'ai supprimer le second et bien j'ai enfin du GRIP VictoireV
Donc attention GaztéroPad et de retour ça va Ch..r Mr. Green .
Quand même bizarre  cette histoire de circuit qui se fusionne et que je puisse entrée sur le serveur Shocked
PostPosted: Sat 4 Dec 2010 - 20:03    Post subject: [9 12 2010] TSUKUBA CHAMPIONNAT VdM MEGANE TROPHY Reply with quote
COOL, gaz
je suis aller tourner cet ap avec evrix ,belle arsouille ca promet !
PostPosted: Sat 4 Dec 2010 - 21:17    Post subject: [9 12 2010] TSUKUBA CHAMPIONNAT VdM MEGANE TROPHY Reply with quote
Deux versions de Tsukuba???....Version drift??? .........
Le drift c'est le sport des retard mentales... Laughing
PostPosted: Sun 5 Dec 2010 - 00:57    Post subject: [9 12 2010] TSUKUBA CHAMPIONNAT VdM MEGANE TROPHY Reply with quote
 mon ami!!!
Page 1 of 5
